Inserting gobo projections
A pattern, texture, or color can be placed on a lighting device and projected onto the stage. This special light source and device combination is a gobo projection.
Lighting devices with gobo projections cast a light beam that can be rendered. You can then preview the effect of the gobo projection textures on the stage. For more information on rendering, see Concept: Best rendering practices.
